Ana içeriğe geç
Olympus TG-820 iHS Locking Mechanism Replacement
Neye ihtiyacın var
  1. Olympus TG-820 iHS Locking Mechanism Replacement, Battery: adım 1, 1 resimden 1.
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Locking Mechanism Replacement: adım 2, 3 resimden 1. Olympus TG-820 iHS Locking Mechanism Replacement: adım 2, 3 resimden 2. Olympus TG-820 iHS Locking Mechanism Replacement: adım 2, 3 resimden 3.
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Locking Mechanism Replacement: adım 3, 2 resimden 1. Olympus TG-820 iHS Locking Mechanism Replacement: adım 3, 2 resimden 2.
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: adım 4, 3 resimden 1. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: adım 4, 3 resimden 2. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: adım 4, 3 resimden 3.
    • Locate and remove the 4.7mm Phillips #000 screw on the back side of the battery compartment locking mechanism.
    • Locate and remove the 4.7mm Phillips #000 screw on the front side of the battery compartment locking mechanism.
  5. Olympus TG-820 iHS Locking Mechanism Replacement: adım 5, 1 resimden 1.
    • Locate the two screws on the side of the battery compartment.
    • Remove the two 4.85mm Phillips #000 screws.
  6. Olympus TG-820 iHS Locking Mechanism Replacement: adım 6, 2 resimden 1. Olympus TG-820 iHS Locking Mechanism Replacement: adım 6, 2 resimden 2.
    • Once all 4 screws are out, the back panel of the battery compartment will come off.
    • The entire battery compartment cover will also detach from the camera.
Sonuç
Larissa Knight
549 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 7-2, Benson Spring 2016 Clemson, Team 7-2, Benson Spring 2016 üyesi
CLEM-BENSON-S16S7G2
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 442
