Ana içeriğe geç
Olympus Tough TG-1 Battery Replacement
  1. Olympus Tough TG-1 Battery Replacement, Battery Removal: adım 1, 1 resimden 1.
    • Release both latches on the battery compartment on the bottom of the camera to open the door.
  2. Olympus Tough TG-1 Battery Replacement: adım 2, 1 resimden 1.
    • After you have removed the latch, open the compartment door to remove the battery.
    • The batteries contain highly acidic contents. If the battery has leaked or ruptured while inside the compartment, there may be damage to the camera's circuitry. Carefully clean out any residue from the battery using latex gloves and tissues.
    • If the compartment door is loose, check the hinge or the locking pieces under the rubber pad. To do this, unscrew and remove the rubber and metal plate on the door.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Richard Yacobellis
225 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Brown Winter 2015 USF Tampa, Team 4-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,013
