Ana içeriğe geç
Olympus Tough TG-1 Circuit Board For Back Buttons Replacement
Neye ihtiyacın var
  1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Clip Side Repair: adım 1, 2 resimden 1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Clip Side Repair: adım 1, 2 resimden 2.
    • Remove both 6 mm screws from the clip side of the camera.
    • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • If one of more of the clips appear to be broken, the back plate might need to be replaced.
  2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Top of Camera: adım 2, 1 resimden 1.
    • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
  3. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: adım 3, 3 resimden 1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: adım 3, 3 resimden 2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: adım 3, 3 resimden 3.
    • Remove the two 5 mm screws on the side of the camera with the plug.
    • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
  4. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Bottom: adım 4, 1 resimden 1.
    • Turn the camera so that you are looking at the bottom of the camera.
    • Remove the two 4 mm screws from the bottom of the camera.
    • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
  5. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: adım 5, 3 resimden 1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: adım 5, 3 resimden 2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: adım 5, 3 resimden 3.
    • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
    • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
  6. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: adım 6, 3 resimden 1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: adım 6, 3 resimden 2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: adım 6, 3 resimden 3.
    • Using the plastic opening tools, carefully open the case.
    • Do not tear the white circuit ribbon.
  7. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: adım 7, 3 resimden 1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: adım 7, 3 resimden 2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: adım 7, 3 resimden 3.
    • Using the screwdriver, remove the ten 3mm anchor screws.
    • Using the plastic opening tool, open the protective cover so that the screen is exposed.
  8. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Unclipping the Screen from the Circuit Ribbon: adım 8, 1 resimden 1.
    • Carefully unclip the screen from its circuit ribbon.
  9. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Circuit Board For Back Buttons: adım 9, 1 resimden 1.
    • After removing this plastic casing from the screen, the only thing holding the circuit board to the plate is a screw 3 mm in length, with a diameter of 2.5 mm. Remove this screw.
  10. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement: adım 10, 1 resimden 1.
    • This is what your device should look like after removing the one screw.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Feliciano
122 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Brown Winter 2015 USF Tampa, Team 4-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 865
