Ana içeriğe geç
Olympus VR-350 Back Plate Replacement
Neye ihtiyacın var
  1. Olympus VR-350 Back Plate Replacement, Front Plate: adım 1, 2 resimden 1. Olympus VR-350 Back Plate Replacement, Front Plate: adım 1, 2 resimden 2.
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Back Plate Replacement: adım 2, 1 resimden 1.
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Back Plate Replacement: adım 3, 3 resimden 1. Olympus VR-350 Back Plate Replacement: adım 3, 3 resimden 2. Olympus VR-350 Back Plate Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Back Plate Replacement, Back Plate: adım 4, 2 resimden 1. Olympus VR-350 Back Plate Replacement, Back Plate: adım 4, 2 resimden 2.
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
Sonuç
Adri
456 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Winter 2015 USF Tampa, Team 1-3, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 672
