Ana içeriğe geç
Olympus VR-350 LCD Screen Replacement
Neye ihtiyacın var
  1. Olympus VR-350 LCD Screen Replacement, Front Plate: adım 1, 2 resimden 1. Olympus VR-350 LCD Screen Replacement, Front Plate: adım 1, 2 resimden 2.
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Olympus VR-350 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Olympus VR-350 LCD Screen Replacement: adım 3, 3 resimden 1. Olympus VR-350 LCD Screen Replacement: adım 3, 3 resimden 2. Olympus VR-350 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
    FixBot'a Sor
    Yorum Ekle
  4. Olympus VR-350 LCD Screen Replacement, Back Plate: adım 4, 2 resimden 1. Olympus VR-350 LCD Screen Replacement, Back Plate: adım 4, 2 resimden 2.
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
    FixBot'a Sor
    Yorum Ekle
  5. Olympus VR-350 LCD Screen Replacement, LCD Screen: adım 5, 2 resimden 1. Olympus VR-350 LCD Screen Replacement, LCD Screen: adım 5, 2 resimden 2.
    • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
    FixBot'a Sor
    Yorum Ekle
  6. Olympus VR-350 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Pull the button pad up to fully reveal the visible ribbon cable.
    • You might need to bend the button pad out of the way.
    FixBot'a Sor
    Yorum Ekle
  7. Olympus VR-350 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Pull out the LCD screen and the ribbon cable.
    • The ribbon cable should be easy to pull out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Chloe
112 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Winter 2015 USF Tampa, Team 1-3, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G3
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 1,589
