Giriş
This guide will help you replace your LCD screen.
Neye ihtiyacın var
Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
Sonuç
