Ana içeriğe geç
Olympus VR-350 Lens Box Unit Replacement
Neye ihtiyacın var
    1. Olympus VR-350 Lens Box Unit Replacement, Front Plate: adım 1, 2 resimden 1. Olympus VR-350 Lens Box Unit Replacement, Front Plate: adım 1, 2 resimden 2.
      • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus VR-350 Lens Box Unit Replacement: adım 2, 1 resimden 1.
      • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus VR-350 Lens Box Unit Replacement: adım 3, 3 resimden 1. Olympus VR-350 Lens Box Unit Replacement: adım 3, 3 resimden 2. Olympus VR-350 Lens Box Unit Replacement: adım 3, 3 resimden 3.
      • Use the plastic opening tools and your fingers to pry the front plate from the camera.
      • You might need to open the battery cover to remove the front plate.
      FixBot'a Sor
      Yorum Ekle
    1. Olympus VR-350 Lens Box Unit Replacement, Back Plate: adım 4, 2 resimden 1. Olympus VR-350 Lens Box Unit Replacement, Back Plate: adım 4, 2 resimden 2.
      • Use your fingers to pry open the back cover.
      • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
      • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
      FixBot'a Sor
      Yorum Ekle
    1. Olympus VR-350 Lens Box Unit Replacement, LCD Screen: adım 5, 2 resimden 1. Olympus VR-350 Lens Box Unit Replacement, LCD Screen: adım 5, 2 resimden 2.
      • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus VR-350 Lens Box Unit Replacement: adım 6, 1 resimden 1.
      • Pull the button pad up to fully reveal the visible ribbon cable.
      • You might need to bend the button pad out of the way.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus VR-350 Lens Box Unit Replacement: adım 7, 1 resimden 1.
      • Pull out the LCD screen and the ribbon cable.
      • The ribbon cable should be easy to pull out.
      FixBot'a Sor
      Yorum Ekle
    1. Olympus VR-350 Lens Box Unit Replacement, Lens Box Unit: adım 8, 1 resimden 1.
      • Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus VR-350 Lens Box Unit Replacement: adım 9, 2 resimden 1. Olympus VR-350 Lens Box Unit Replacement: adım 9, 2 resimden 2.
      • Remove the orange ribbon cable from the connector on the left side of the motherboard.
      • To do this, gently lift up the small grey clasp and pull the cable ribbon.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus VR-350 Lens Box Unit Replacement: adım 10, 1 resimden 1.
      • There are two other small ribbon cables under the motherboard connected to the lens box. Pull them out from the motherboard.
      • You may need to use force to pull out the ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    4. Olympus VR-350 Lens Box Unit Replacement: adım 11, 1 resimden 1.
      • Pull the lens box up and out to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Brooke
278 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Winter 2015 USF Tampa, Team 1-3, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G3
3 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
Rick Allies - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 52
Her zaman: 2,382
