Ana içeriğe geç
Omaker M4 Battery Replacement
Neye ihtiyacın var
  1. Omaker M4 Battery Replacement, Back Case: adım 1, 1 resimden 1.
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: adım 2, 2 resimden 1. Omaker M4 Battery Replacement: adım 2, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: adım 3, 2 resimden 1. Omaker M4 Battery Replacement: adım 3, 2 resimden 2.
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: adım 4, 1 resimden 1.
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: adım 5, 2 resimden 1. Omaker M4 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: adım 6, 3 resimden 1. Omaker M4 Battery Replacement, Battery: adım 6, 3 resimden 2. Omaker M4 Battery Replacement, Battery: adım 6, 3 resimden 3.
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Carlos Pernia
170 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Sullivan Spring 2016 USF Tampa, Team 2-2, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G2
3 Üyeler
2 adet Kılavuz yazıldı
Bir Yorum
What battery is required for this though? Is it easily found on amazon?
Mohsin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,330
