Ana içeriğe geç
Omaker M4 Motherboard Replacement
Neye ihtiyacın var
    1. Omaker M4 Motherboard Replacement, Back Case: adım 1, 1 resimden 1.
      • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
      FixBot'a Sor
      Yorum Ekle
    2. Omaker M4 Motherboard Replacement: adım 2, 2 resimden 1. Omaker M4 Motherboard Replacement: adım 2, 2 resimden 2.
      • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Omaker M4 Motherboard Replacement: adım 3, 2 resimden 1. Omaker M4 Motherboard Replacement: adım 3, 2 resimden 2.
      • Use a magnet to remove the screws after unscrewing them and place them aside.
      FixBot'a Sor
      Yorum Ekle
    4. Omaker M4 Motherboard Replacement: adım 4, 1 resimden 1.
      • Carefully remove the back cover without breaking the battery wire.
      FixBot'a Sor
      Yorum Ekle
    5. Omaker M4 Motherboard Replacement: adım 5, 2 resimden 1. Omaker M4 Motherboard Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
      • The battery is still attached to the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. Omaker M4 Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Omaker M4 Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
      • Remove the mic wire by carefully pulling the plug out of the socket.
      FixBot'a Sor
      Yorum Ekle
    2. Omaker M4 Motherboard Replacement: adım 7, 1 resimden 1.
      • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Omaker M4 Motherboard Replacement: adım 8, 2 resimden 1. Omaker M4 Motherboard Replacement: adım 8, 2 resimden 2.
      • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
      FixBot'a Sor
      Yorum Ekle
    4. Omaker M4 Motherboard Replacement: adım 9, 2 resimden 1. Omaker M4 Motherboard Replacement: adım 9, 2 resimden 2.
      • Remove the screws using the screwdriver.
      • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
      FixBot'a Sor
      Yorum Ekle
    5. Omaker M4 Motherboard Replacement: adım 10, 2 resimden 1. Omaker M4 Motherboard Replacement: adım 10, 2 resimden 2.
      • Carefully remove the motherboard with your hand by lifting it from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
[deleted]
679 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 1,679
