Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Omaker M4 Port Cover Replacement
Neye ihtiyacın var
  1. Omaker M4 Port Cover Replacement, Back Case: adım 1, 1 resimden 1.
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Port Cover Replacement: adım 2, 2 resimden 1. Omaker M4 Port Cover Replacement: adım 2, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Port Cover Replacement: adım 3, 2 resimden 1. Omaker M4 Port Cover Replacement: adım 3, 2 resimden 2.
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Port Cover Replacement: adım 4, 1 resimden 1.
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Port Cover Replacement: adım 5, 2 resimden 1. Omaker M4 Port Cover Replacement: adım 5, 2 resimden 2.
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Port Cover Replacement, Motherboard: adım 6, 2 resimden 1. Omaker M4 Port Cover Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Port Cover Replacement: adım 7, 1 resimden 1.
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Port Cover Replacement: adım 8, 2 resimden 1. Omaker M4 Port Cover Replacement: adım 8, 2 resimden 2.
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Port Cover Replacement: adım 9, 2 resimden 1. Omaker M4 Port Cover Replacement: adım 9, 2 resimden 2.
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Port Cover Replacement: adım 10, 2 resimden 1. Omaker M4 Port Cover Replacement: adım 10, 2 resimden 2.
    • Carefully remove the motherboard with your hand by lifting it from the device.
  11. Omaker M4 Port Cover Replacement, Port Cover: adım 11, 2 resimden 1. Omaker M4 Port Cover Replacement, Port Cover: adım 11, 2 resimden 2.
    • Separate the port cover from the device using your hands.
  12. Omaker M4 Port Cover Replacement: adım 12, 1 resimden 1.
    • Orient the device so the port cover is on your left.
  13. Omaker M4 Port Cover Replacement: adım 13, 2 resimden 1. Omaker M4 Port Cover Replacement: adım 13, 2 resimden 2.
    • Using Tweezers, pinch the larger part of the stem
  14. Omaker M4 Port Cover Replacement: adım 14, 1 resimden 1.
    • Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Obaida Matar
119 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Sullivan Spring 2016 USF Tampa, Team 2-2, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G2
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 365
