Ana içeriğe geç
OnHub Speaker Grille Replacement
Neye ihtiyacın var
  1. OnHub Speaker Grille Replacement, Speaker Grille: adım 1, 2 resimden 1. OnHub Speaker Grille Replacement, Speaker Grille: adım 1, 2 resimden 2.
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub Speaker Grille Replacement: adım 2, 1 resimden 1.
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub Speaker Grille Replacement: adım 3, 2 resimden 1. OnHub Speaker Grille Replacement: adım 3, 2 resimden 2.
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joseph Ainsworth
544 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Sullivan Spring 2016 USF Tampa, Team 3-3, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S3G3
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 314
