Ana içeriğe geç
Onda V701 Battery Replacement
Neye ihtiyacın var
    1. Onda V701 Battery Replacement, Back Panel: adım 1, 3 resimden 1. Onda V701 Battery Replacement, Back Panel: adım 1, 3 resimden 2. Onda V701 Battery Replacement, Back Panel: adım 1, 3 resimden 3.
      • Ensure device is powered off before disassembly.
      • Remove the 4 rubber screw plugs using a spudger.
      FixBot'a Sor
      Yorum Ekle
    2. Onda V701 Battery Replacement: adım 2, 3 resimden 1. Onda V701 Battery Replacement: adım 2, 3 resimden 2. Onda V701 Battery Replacement: adım 2, 3 resimden 3.
      • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Onda V701 Battery Replacement: adım 3, 2 resimden 1. Onda V701 Battery Replacement: adım 3, 2 resimden 2.
      • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
      • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
      FixBot'a Sor
      Yorum Ekle
    4. Onda V701 Battery Replacement: adım 4, 2 resimden 1. Onda V701 Battery Replacement: adım 4, 2 resimden 2.
      • Gently lift the screen assembly away from the back cover assembly.
      • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    5. Onda V701 Battery Replacement: adım 5, 3 resimden 1. Onda V701 Battery Replacement: adım 5, 3 resimden 2. Onda V701 Battery Replacement: adım 5, 3 resimden 3.
      • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
      • Remove the ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    1. Onda V701 Battery Replacement, Battery: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Desolder the red(+) and black(-) wires connecting the battery to the motherboard using a soldering iron and tweezers to hold the wire.
      • Soldering requires a lot of heat. Do not touch the metal part of the soldering iron. Wear gloves if necessary to protect your hands. The fumes from soldering could also be toxic. Work in a well ventilated area and/or use a respirator.
      FixBot'a Sor
      Yorum Ekle
    2. Onda V701 Battery Replacement: adım 7, 3 resimden 1. Onda V701 Battery Replacement: adım 7, 3 resimden 2. Onda V701 Battery Replacement: adım 7, 3 resimden 3.
      • Carefully pry the battery away from the back panel using the nylon or metal spudger.
      • Gently remove the battery from the back panel.
      • Ensure not to excessively bend or puncture the battery. Doing so could cause the battery to catch on fire or explode.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bradley Huber
366 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-6, Panko Spring 2015 Colorado Springs, Team 4-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,270
