Ana içeriğe geç
Onda V701 Front- Facing Camera Replacement
Neye ihtiyacın var
  1. Onda V701 Front- Facing Camera Replacement, Back Panel: adım 1, 3 resimden 1. Onda V701 Front- Facing Camera Replacement, Back Panel: adım 1, 3 resimden 2. Onda V701 Front- Facing Camera Replacement, Back Panel: adım 1, 3 resimden 3.
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Front- Facing Camera Replacement: adım 2, 3 resimden 1. Onda V701 Front- Facing Camera Replacement: adım 2, 3 resimden 2. Onda V701 Front- Facing Camera Replacement: adım 2, 3 resimden 3.
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Front- Facing Camera Replacement: adım 3, 2 resimden 1. Onda V701 Front- Facing Camera Replacement: adım 3, 2 resimden 2.
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Front- Facing Camera Replacement: adım 4, 2 resimden 1. Onda V701 Front- Facing Camera Replacement: adım 4, 2 resimden 2.
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Front- Facing Camera Replacement: adım 5, 3 resimden 1. Onda V701 Front- Facing Camera Replacement: adım 5, 3 resimden 2. Onda V701 Front- Facing Camera Replacement: adım 5, 3 resimden 3.
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: adım 6, 2 resimden 1. Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: adım 6, 2 resimden 2.
    • Gently pry the front-facing camera away from the back panel using a spudger.
  7. Onda V701 Front- Facing Camera Replacement: adım 7, 2 resimden 1. Onda V701 Front- Facing Camera Replacement: adım 7, 2 resimden 2.
    • Flip the gray locking tab of the ribbon connector up using a spudger.
    • Remove the ribbon cable from the connector.
  8. Onda V701 Front- Facing Camera Replacement: adım 8, 1 resimden 1.
    • Remove the front-facing camera assembly.
Sonuç
Bradley Huber
366 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-6, Panko Spring 2015 Colorado Springs, Team 4-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 273
