Ana içeriğe geç
Onda VI10 Battery Replacement
Neye ihtiyacın var
  1. Onda VI10  Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use a number 0 screw driver to remove the four screws.
  2. Onda VI10  Battery Replacement: adım 2, 1 resimden 1.
    • Power Button on the side should be pointing outward.
    • Note: This is so the ribbon cables are not damaged.
  3. Onda VI10  Battery Replacement: adım 3, 1 resimden 1.
    • Heat up the back of the device with a hair dryer to loosen the glue.
  4. Onda VI10  Battery Replacement: adım 4, 1 resimden 1.
    • Pry up battery from plastic using a nylon spudger or plastic opening tool.
  5. Onda VI10  Battery Replacement: adım 5, 1 resimden 1.
    • Desolder the two battery cables from the mother board.
Sonuç
Clint Richards
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G3, Baechle Spring 2017 IUPUI, Team S4-G3, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S4G3
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Hi ! Thx for the tuto !
Were can i shop thé battery ?! Please ? I live in France...
mauriciano67 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 655
