Ana içeriğe geç
Onda VI10 Screen Replacement
Neye ihtiyacın var
    1. Onda VI10  Screen Replacement, Screen: adım 1, 1 resimden 1.
      • Remove four Phillips head screws from back with #0 screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. Onda VI10  Screen Replacement: adım 2, 2 resimden 1. Onda VI10  Screen Replacement: adım 2, 2 resimden 2.
      • Separate the back from the screen and open as shown. Make sure to open from the side with the power button to avoid damaging the ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    3. Onda VI10  Screen Replacement: adım 3, 1 resimden 1.
      • Using the plastic spudger, lift the black latches for the ribbon cables and slide the cables out of their sockets. Now the two halves can be separated.
      FixBot'a Sor
      Yorum Ekle
    4. Onda VI10  Screen Replacement: adım 4, 1 resimden 1.
      • There are 14 3mm long screws surrounding the screen. Using the #00 Phillips screwdriver, remove all of these screws.
      FixBot'a Sor
      Yorum Ekle
    5. Onda VI10  Screen Replacement: adım 5, 1 resimden 1.
      • Using the metal spudger, depress the four plastic tabs to free the glass from the display.
      FixBot'a Sor
      Yorum Ekle
    6. Onda VI10  Screen Replacement: adım 6, 1 resimden 1.
      • Use the metal spudger again to get between the glass and the chrome trim ring. Lightly pry the glass away from the display. If this proves difficult, double check that all of the screws have been removed and that all four plastic clips are pushed in. Again, start from the side opposite the ribbon cable to avoid damaging it.
      FixBot'a Sor
      Yorum Ekle
    7. Onda VI10  Screen Replacement: adım 7, 1 resimden 1.
      • Once the glass and display have been separated, pull the glass away from the display and carefully slide the ribbon cable out of the display housing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Solomon Hunter
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G3, Baechle Spring 2017 IUPUI, Team S4-G3, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S4G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 563
