Ana içeriğe geç
Onda VI10 Speaker Replacement
Neye ihtiyacın var
  1. Onda VI10 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Use a number 0 screw driver to remove the four screws.
  2. Onda VI10 Speaker Replacement: adım 2, 1 resimden 1.
    • Power Button on the side should be pointing outward.
    • Note: This is so the ribbon cables inside are not damaged.
  3. Onda VI10 Speaker Replacement: adım 3, 1 resimden 1.
    • Locate the black and red speaker wires going back to the mother board.
    • Note: Speaker wires may run underneath the battery wires.
  4. Onda VI10 Speaker Replacement: adım 4, 1 resimden 1.
    • Carefully remove the speaker cables from the retaining tabs using a thin metal spudger.
  5. Onda VI10 Speaker Replacement: adım 5, 1 resimden 1.
    • Pry the speaker out of its molding using a thin metal spudger
  6. Onda VI10 Speaker Replacement: adım 6, 1 resimden 1.
    • Desolder the two speaker wires from the motherboard using a soldering iron.
    • Caution: Soldering Iron is extremely hot.
Sonuç
Carlos Diaz
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G3, Baechle Spring 2017 IUPUI, Team S4-G3, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S4G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 142
