Ana içeriğe geç
One Education Infinity Battery Replacement
Neye ihtiyacın var
  1. One Education Infinity Battery Replacement, Back Case: adım 1, 3 resimden 1. One Education Infinity Battery Replacement, Back Case: adım 1, 3 resimden 2. One Education Infinity Battery Replacement, Back Case: adım 1, 3 resimden 3.
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  2. One Education Infinity Battery Replacement: adım 2, 2 resimden 1. One Education Infinity Battery Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. One Education Infinity Battery Replacement: adım 3, 3 resimden 1. One Education Infinity Battery Replacement: adım 3, 3 resimden 2. One Education Infinity Battery Replacement: adım 3, 3 resimden 3.
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
    FixBot'a Sor
    Yorum Ekle
  4. One Education Infinity Battery Replacement, Battery: adım 4, 3 resimden 1. One Education Infinity Battery Replacement, Battery: adım 4, 3 resimden 2. One Education Infinity Battery Replacement, Battery: adım 4, 3 resimden 3.
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
    FixBot'a Sor
    Yorum Ekle
  5. One Education Infinity Battery Replacement: adım 5, 3 resimden 1. One Education Infinity Battery Replacement: adım 5, 3 resimden 2. One Education Infinity Battery Replacement: adım 5, 3 resimden 3.
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jacob Barnes
193 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G4, Regan Fall 2019 Cal Poly, Team S11-G4, Regan Fall 2019 üyesi
CPSU-REGAN-F19S11G4
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 34
Her zaman: 663
