Ana içeriğe geç
One Education Infinity Solid State Drive Replacement
Neye ihtiyacın var
  1. One Education Infinity Solid State Drive Replacement, Back Case: adım 1, 3 resimden 1. One Education Infinity Solid State Drive Replacement, Back Case: adım 1, 3 resimden 2. One Education Infinity Solid State Drive Replacement, Back Case: adım 1, 3 resimden 3.
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Solid State Drive Replacement: adım 2, 2 resimden 1. One Education Infinity Solid State Drive Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Solid State Drive Replacement: adım 3, 3 resimden 1. One Education Infinity Solid State Drive Replacement: adım 3, 3 resimden 2. One Education Infinity Solid State Drive Replacement: adım 3, 3 resimden 3.
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Solid State Drive Replacement, Battery: adım 4, 3 resimden 1. One Education Infinity Solid State Drive Replacement, Battery: adım 4, 3 resimden 2. One Education Infinity Solid State Drive Replacement, Battery: adım 4, 3 resimden 3.
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Solid State Drive Replacement: adım 5, 3 resimden 1. One Education Infinity Solid State Drive Replacement: adım 5, 3 resimden 2. One Education Infinity Solid State Drive Replacement: adım 5, 3 resimden 3.
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Solid State Drive Replacement, Solid State Drive: adım 6, 3 resimden 1. One Education Infinity Solid State Drive Replacement, Solid State Drive: adım 6, 3 resimden 2. One Education Infinity Solid State Drive Replacement, Solid State Drive: adım 6, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
  7. One Education Infinity Solid State Drive Replacement: adım 7, 3 resimden 1. One Education Infinity Solid State Drive Replacement: adım 7, 3 resimden 2. One Education Infinity Solid State Drive Replacement: adım 7, 3 resimden 3.
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
Sonuç
Ekip
Cal Poly, Team S11-G4, Regan Fall 2019 Cal Poly, Team S11-G4, Regan Fall 2019 üyesi
CPSU-REGAN-F19S11G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 10
Her zaman: 257
