Ana içeriğe geç
One Education Infinity:One Battery Replacement
  1. One Education Infinity:One Battery Replacement, Top Case: adım 1, 3 resimden 1. One Education Infinity:One Battery Replacement, Top Case: adım 1, 3 resimden 2. One Education Infinity:One Battery Replacement, Top Case: adım 1, 3 resimden 3.
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Battery Replacement, Battery: adım 2, 2 resimden 1. One Education Infinity:One Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  3. One Education Infinity:One Battery Replacement: adım 3, 3 resimden 1. One Education Infinity:One Battery Replacement: adım 3, 3 resimden 2. One Education Infinity:One Battery Replacement: adım 3, 3 resimden 3.
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  4. One Education Infinity:One Battery Replacement: adım 4, 3 resimden 1. One Education Infinity:One Battery Replacement: adım 4, 3 resimden 2. One Education Infinity:One Battery Replacement: adım 4, 3 resimden 3.
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. One Education Infinity:One Battery Replacement: adım 5, 1 resimden 1.
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Bratsch
5.543 İtibar
14 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 909
