Ana içeriğe geç
One Education Infinity:One Battery Replacement
Neye ihtiyacın var
  1. One Education Infinity:One Battery Replacement, Top Case: adım 1, 3 resimden 1. One Education Infinity:One Battery Replacement, Top Case: adım 1, 3 resimden 2. One Education Infinity:One Battery Replacement, Top Case: adım 1, 3 resimden 3.
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Battery Replacement, Battery: adım 2, 2 resimden 1. One Education Infinity:One Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  3. One Education Infinity:One Battery Replacement: adım 3, 3 resimden 1. One Education Infinity:One Battery Replacement: adım 3, 3 resimden 2. One Education Infinity:One Battery Replacement: adım 3, 3 resimden 3.
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  4. One Education Infinity:One Battery Replacement: adım 4, 3 resimden 1. One Education Infinity:One Battery Replacement: adım 4, 3 resimden 2. One Education Infinity:One Battery Replacement: adım 4, 3 resimden 3.
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. One Education Infinity:One Battery Replacement: adım 5, 1 resimden 1.
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Bratsch
6.089 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,131
