Ana içeriğe geç
Giriş
In the One Education Infinity:One laptop, the front and rear facing cameras are one component. If you are experiencing performance issues with either camera this guide will help you replace them.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use a spudger to disconnect the black bundled cable connector from the motherboard. Use a spudger to disconnect the black bundled cable connector from the motherboard.
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. Use a spudger to lift the black tab on top of the ZIF connector. Slide the ribbon cable out of the connector. Slide the ribbon cable out of the connector.
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. Use a spudger to flip up the black retaining flap on the ZIF connector. Pull the folded ribbon cable straight out of the connector. This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. Use a spudger to pry the battery away from the device.
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. Use a spudger to flip up the black flap on the camera's  ZIF connector. Pull the ribbon cable straight out of the connector. Pull the ribbon cable straight out of the connector.
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  6. Use tweezers to remove the black cushion surrounding the camera lens. Use tweezers to remove the black cushion surrounding the camera lens.
    • Use tweezers to remove the black cushion surrounding the camera lens.
  7. Use tweezers to lift the camera assembly away from the device. Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
    • Use tweezers to lift the camera assembly away from the device.
    • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
Sonuç
Taylor Bratsch
5.315 İtibar
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 115
