Ana içeriğe geç
One Education Infinity:One Camera Assembly Replacement
Neye ihtiyacın var
    1. One Education Infinity:One Camera Assembly Replacement, Battery: adım 1, 2 resimden 1. One Education Infinity:One Camera Assembly Replacement, Battery: adım 1, 2 resimden 2.
      • Use a spudger to disconnect the black bundled cable connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. One Education Infinity:One Camera Assembly Replacement: adım 2, 3 resimden 1. One Education Infinity:One Camera Assembly Replacement: adım 2, 3 resimden 2. One Education Infinity:One Camera Assembly Replacement: adım 2, 3 resimden 3.
      • Use a spudger to lift the black tab on top of the ZIF connector.
      • Slide the ribbon cable out of the connector.
      FixBot'a Sor
      Yorum Ekle
    3. One Education Infinity:One Camera Assembly Replacement: adım 3, 3 resimden 1. One Education Infinity:One Camera Assembly Replacement: adım 3, 3 resimden 2. One Education Infinity:One Camera Assembly Replacement: adım 3, 3 resimden 3.
      • Use a spudger to flip up the black retaining flap on the ZIF connector.
      • Pull the folded ribbon cable straight out of the connector.
      • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
      FixBot'a Sor
      Yorum Ekle
    4. One Education Infinity:One Camera Assembly Replacement: adım 4, 1 resimden 1.
      • Use a spudger to pry the battery away from the device.
      • Always use ESD safe tools when working with delicate electrical components.
      FixBot'a Sor
      Yorum Ekle
    1. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: adım 5, 3 resimden 1. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: adım 5, 3 resimden 2. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: adım 5, 3 resimden 3.
      • Use a spudger to flip up the black flap on the camera's ZIF connector.
      • Pull the ribbon cable straight out of the connector.
      FixBot'a Sor
      Yorum Ekle
    2. One Education Infinity:One Camera Assembly Replacement: adım 6, 2 resimden 1. One Education Infinity:One Camera Assembly Replacement: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use tweezers to remove the black cushion surrounding the camera lens.
      FixBot'a Sor
      Yorum Ekle
    3. One Education Infinity:One Camera Assembly Replacement: adım 7, 2 resimden 1. One Education Infinity:One Camera Assembly Replacement: adım 7, 2 resimden 2.
      • Use tweezers to lift the camera assembly away from the device.
      • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Bratsch
6.168 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 549
