Ana içeriğe geç
One Education Infinity:One Dock Contact Assembly Replacement
  1. One Education Infinity:One Dock Contact Assembly Replacement, Battery: adım 1, 2 resimden 1. One Education Infinity:One Dock Contact Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Dock Contact Assembly Replacement: adım 2, 3 resimden 1. One Education Infinity:One Dock Contact Assembly Replacement: adım 2, 3 resimden 2. One Education Infinity:One Dock Contact Assembly Replacement: adım 2, 3 resimden 3.
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Dock Contact Assembly Replacement: adım 3, 3 resimden 1. One Education Infinity:One Dock Contact Assembly Replacement: adım 3, 3 resimden 2. One Education Infinity:One Dock Contact Assembly Replacement: adım 3, 3 resimden 3.
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Dock Contact Assembly Replacement: adım 4, 1 resimden 1.
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Dock Contact Assembly Replacement, Dock Contact Assembly: adım 5, 1 resimden 1.
    • Use tweezers to pull the dock contact display cable away from the connector on the motherboard.
  6. One Education Infinity:One Dock Contact Assembly Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #000 screwdriver to unscrew the two 4.2mm screws from the circuit board containing the dock contact.
  7. One Education Infinity:One Dock Contact Assembly Replacement: adım 7, 1 resimden 1.
    • Lift the dock contact assembly away from the device.
Sonuç
Taylor Bratsch
5.477 İtibar
14 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 116
