Ana içeriğe geç
OneLink Safe and Sound Motherboard Replacement
Neye ihtiyacın var
  1. OneLink Safe and Sound Motherboard Replacement, Cover: adım 1, 2 resimden 1. OneLink Safe and Sound Motherboard Replacement, Cover: adım 1, 2 resimden 2.
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
  2. OneLink Safe and Sound Motherboard Replacement: adım 2, 2 resimden 1. OneLink Safe and Sound Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
  3. OneLink Safe and Sound Motherboard Replacement: adım 3, 2 resimden 1. OneLink Safe and Sound Motherboard Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
  4. OneLink Safe and Sound Motherboard Replacement: adım 4, 1 resimden 1.
    • Use tweezers to unplug the speaker cable from the motherboard.
  5. OneLink Safe and Sound Motherboard Replacement: adım 5, 2 resimden 1. OneLink Safe and Sound Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
  6. OneLink Safe and Sound Motherboard Replacement, Battery: adım 6, 1 resimden 1.
    • Use the plastic opening tool to disconnect the cable from the motherboard.
  7. OneLink Safe and Sound Motherboard Replacement: adım 7, 2 resimden 1. OneLink Safe and Sound Motherboard Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
  8. OneLink Safe and Sound Motherboard Replacement: adım 8, 2 resimden 1. OneLink Safe and Sound Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the plastic cage holding the battery in place.
    • Remove the battery from the device.
  9. OneLink Safe and Sound Motherboard Replacement, Bluetooth Module: adım 9, 1 resimden 1.
    • Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
  10. OneLink Safe and Sound Motherboard Replacement: adım 10, 2 resimden 1. OneLink Safe and Sound Motherboard Replacement: adım 10, 2 resimden 2.
    • Lift the Bluetooth module off of the daughterboard.
    • Lift it straight up to avoid bending the delicate pins that connect the Bluetooth module to the board.
  11. OneLink Safe and Sound Motherboard Replacement, Motherboard: adım 11, 3 resimden 1. OneLink Safe and Sound Motherboard Replacement, Motherboard: adım 11, 3 resimden 2. OneLink Safe and Sound Motherboard Replacement, Motherboard: adım 11, 3 resimden 3.
    • Use the opening tool to disconnect the speaker cables from the daughterboard.
    • Use the opening to lift the daughterboard off of the motherboard.
    • The daughterboard is sitting on a white plastic base on top of the motherboard.
  12. OneLink Safe and Sound Motherboard Replacement: adım 12, 2 resimden 1. OneLink Safe and Sound Motherboard Replacement: adım 12, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove seven screws securing the white base and motherboard.
  13. OneLink Safe and Sound Motherboard Replacement: adım 13, 3 resimden 1. OneLink Safe and Sound Motherboard Replacement: adım 13, 3 resimden 2. OneLink Safe and Sound Motherboard Replacement: adım 13, 3 resimden 3.
    • Gently remove the motherboard.
Sonuç
Arianna Roberts
639 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Petersen Fall 2022 UMass Dartmouth, Team 2-2, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 111
