Ana içeriğe geç
OnePlus 12 Back Glass Replacement
Neye ihtiyacın var
    1. OnePlus 12 Back Glass Replacement, Back Glass: adım 1, 1 resimden 1.
      • Ensure the phone is powered off and placed with the back glass facing towards you on a stable surface.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 12 Back Glass Replacement: adım 2, 2 resimden 1. OnePlus 12 Back Glass Replacement: adım 2, 2 resimden 2.
      • Pop open the SIM card tray by inserting a SIM card removal tool into the SIM card tray on the bottom of the phone.
      • Remove the SIM card tray from the phone and set it aside for when we are done.
      FixBot'a Sor
      Yorum Ekle
      • Loosen the glue holding the back glass in place by using a hairdryer or an iOpener.
      • If you use a hairdryer, hold it at least a few inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone - not the center.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 12 Back Glass Replacement: adım 4, 2 resimden 1. OnePlus 12 Back Glass Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      Jimmy
      $7.95
      • Insert a Jimmy into the seam of the back glass to lift it slightly. Try to reduce pressure on any single spot of the glass to avoid cracking it.
      • Insert a plastic card underneath the small gap created on the back glass and gently glide the card under the lifted glass.
      • Remove the back glass from the phone by working your way around the glass slowly. You may need to re-heat after a while to keep the glue soft. Otherwise, you may shatter the glass.
      • Use isopropyl alcohol and a lint-free cloth to remove any leftover adhesive and adhesive residue from the frame of the phone (and the back glass if you are re-using it). Do not skip this or else the back glass may not stick on properly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
ThatStella7922
526 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 43
Son 30 gün: 70
Her zaman: 70
