Ana içeriğe geç
OnePlus 2 Battery Replacement
Neye ihtiyacın var
  1. OnePlus 2 Battery Replacement, SIM Card: adım 1, 3 resimden 1. OnePlus 2 Battery Replacement, SIM Card: adım 1, 3 resimden 2. OnePlus 2 Battery Replacement, SIM Card: adım 1, 3 resimden 3.
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
  2. OnePlus 2 Battery Replacement: adım 2, 3 resimden 1. OnePlus 2 Battery Replacement: adım 2, 3 resimden 2. OnePlus 2 Battery Replacement: adım 2, 3 resimden 3.
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
  3. OnePlus 2 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the SIM card tray
  4. OnePlus 2 Battery Replacement, Battery: adım 4, 3 resimden 1. OnePlus 2 Battery Replacement, Battery: adım 4, 3 resimden 2. OnePlus 2 Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
  5. OnePlus 2 Battery Replacement: adım 5, 3 resimden 1. OnePlus 2 Battery Replacement: adım 5, 3 resimden 2. OnePlus 2 Battery Replacement: adım 5, 3 resimden 3.
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
  6. OnePlus 2 Battery Replacement: adım 6, 3 resimden 1. OnePlus 2 Battery Replacement: adım 6, 3 resimden 2. OnePlus 2 Battery Replacement: adım 6, 3 resimden 3.
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
Sonuç
98 farklı kişi bu kılavuzu tamamladı.
Kayla Williams
1.541 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Maness Fall 2015 Cal Poly, Team 4-5, Maness Fall 2015 üyesi
CPSU-MANESS-F15S4G5
4 Üyeler
19 adet Kılavuz yazıldı
21 Yorum
Nice to see that, thanx !
But do you know where it's possible to buy a new battery ?
I see "designed by oneplus" on it and I'm not sure it would be easy to find one on internet usual stores.
Fred Hamel - Yanıt
You can look up a oneplus service center in your country/locality by going to your country's version of the oneplus site. There in the support -->Contact Us, you will find a list of places(service centers) you can go for repairs and a price list of all the parts and the service to replace them. Not sure if this works for every country, worked for me.
Zuke Denvar -
this is not a full help.. how do we suppose to buy official battery for onelus2?
and this method would be great if you upload a video in full detail without missing any point.
so, please do that. Thanks in advance!
shahfaishalkhan - Yanıt
Use google.com and search for BLP597 that's the itemnumber of the battery in question. There are plenty of sellers available.
Markus Flaig -
any good battery for oneplus 2? i wanna buy a new battery for oneplus 2 can you please suggest me good battery for it? please tell me i really need it asap.
Thank you!!
Aalok Kumar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 52,855
