Giriş
If you are experiencing trouble chairing or plugging in your phone, there may be something wrong with the charging port. This guide will show you have to remove and replace your charging port.
Neye ihtiyacın var
Make sure that your phone is turned off before proceeding
Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
Bu adımda kullanılan alet:Tweezers$4.99
Find and carefully remove all 6 rubber screw covers with the tweezers.
Unscrew all 18 screws from the mid frame.
Use the spudger tool to pry up the top connection of the charging port.
Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
Stop at the next connection.
21 farklı kişi bu kılavuzu tamamladı.
9Kılavuz Yorumları
can you tell me why 2 pins on Charigng Port Flex ?? can I add wireless charger from it? please reply at atulmits@gmail.com
