Ana içeriğe geç
OnePlus 2 Front and Rear Camera Replacement
Neye ihtiyacın var
    1. OnePlus 2 Front and Rear Camera Replacement, SIM Card: adım 1, 3 resimden 1. OnePlus 2 Front and Rear Camera Replacement, SIM Card: adım 1, 3 resimden 2. OnePlus 2 Front and Rear Camera Replacement, SIM Card: adım 1, 3 resimden 3.
      • Make sure that your phone is turned off before proceeding
      • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 2 Front and Rear Camera Replacement: adım 2, 3 resimden 1. OnePlus 2 Front and Rear Camera Replacement: adım 2, 3 resimden 2. OnePlus 2 Front and Rear Camera Replacement: adım 2, 3 resimden 3.
      • Locate the SIM card tray on the back of the phone
      • Use your thumb to gently slide out the tray
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 2 Front and Rear Camera Replacement: adım 3, 1 resimden 1.
      • Remove the SIM card tray
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 2 Front and Rear Camera Replacement, Battery: adım 4, 3 resimden 1. OnePlus 2 Front and Rear Camera Replacement, Battery: adım 4, 3 resimden 2. OnePlus 2 Front and Rear Camera Replacement, Battery: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Find and carefully remove all 6 rubber screw covers with the tweezers.
      • Unscrew all 18 screws from the mid frame.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 2 Front and Rear Camera Replacement: adım 5, 3 resimden 1. OnePlus 2 Front and Rear Camera Replacement: adım 5, 3 resimden 2. OnePlus 2 Front and Rear Camera Replacement: adım 5, 3 resimden 3.
      • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
      • Slowly work your way around the phone releasing all the clips that hold the frame in place.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 2 Front and Rear Camera Replacement: adım 6, 3 resimden 1. OnePlus 2 Front and Rear Camera Replacement: adım 6, 3 resimden 2. OnePlus 2 Front and Rear Camera Replacement: adım 6, 3 resimden 3.
      • Using the spudger tool, pry the battery up from the adhesive.
      • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 2 Front and Rear Camera Replacement, Front and Rear Camera: adım 7, 3 resimden 1. OnePlus 2 Front and Rear Camera Replacement, Front and Rear Camera: adım 7, 3 resimden 2. OnePlus 2 Front and Rear Camera Replacement, Front and Rear Camera: adım 7, 3 resimden 3.
      • Use the spudger tool to pry off the connections at the bottom-right of the front-facing camera.
      • Be sure to disconnect both connections before attempting to lift off the wiring.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 2 Front and Rear Camera Replacement: adım 8, 2 resimden 1. OnePlus 2 Front and Rear Camera Replacement: adım 8, 2 resimden 2.
      • Use the spudger tool to pry off the connection on the left of the front facing camera.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 2 Front and Rear Camera Replacement: adım 9, 2 resimden 1. OnePlus 2 Front and Rear Camera Replacement: adım 9, 2 resimden 2.
      • Use the tweezers to lift up the camera from its groove.
      • The camera has a long, flat portion at the bottom, so be sure to slide the camera up while lifting it up.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus 2 Front and Rear Camera Replacement: adım 10, 3 resimden 1. OnePlus 2 Front and Rear Camera Replacement: adım 10, 3 resimden 2. OnePlus 2 Front and Rear Camera Replacement: adım 10, 3 resimden 3.
      • Use a spudger to pry off the connection below the front-facing camera.
      • Using the tweezers, carefully remove the camera from its groove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Kayla Williams
1.544 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Maness Fall 2015 Cal Poly, Team 4-5, Maness Fall 2015 üyesi
CPSU-MANESS-F15S4G5
4 Üyeler
40 adet Kılavuz yazıldı
5Kılavuz Yorumları
This is awesome guide. My 20 days old onePlus2 lens broke, when my pocket hit the table while I had the phone in there. After reading in the forum about the OnePlus customer service, I did not bother calling OnePlus. I ordered the lens for $5 from parts4repair.com. Followed this awesome directions and replaced the lens without a glitch.
BIG BIG BIG KUDOS to Kayla Williams. This really saved me a lot of time and trouble and made my phone worth again. I can't thank you enough.
Ramesh - Yanıt Paylaş
Dude does that camera lens was real.. I mean like Lens do work like original lens earlier it was? Please reply ASAP!! My camera lens is also broken
Shubham - Yanıt Paylaş
This is a really good guide. My 2 month old one plus 2 was denied service due to some water damage policy. A drop of sweat might have gone in and the service centre says the product is water damaged.
Can you help me with some website where I can find the back camera for one plus 2 please?
Aman Srivastava - Yanıt Paylaş
Hey guys! My OPT fell off a rollercoaster and fortunatly the glass isn't broken at all, but my front camera is damaged. This guide helped me a lot but I can't find that part.
Sadly parts4repair has no front camera lens in its sortiment. Can you give me some websites where I can find the parts
Alex Pulz - Yanıt Paylaş
Have you found any replacement parts? I'm facing the same issue atm
Maarten - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 5,955
