Giriş
If your phone is not switching on, you may be required to replace the motherboard. This guide will help you do so.
Neye ihtiyacın var
Make sure that your phone is turned off before proceeding
Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
Use the spudger tool to pry off the connections at the bottom-right of the front-facing camera.
Be sure to disconnect both connections before attempting to lift off the wiring.
Use the spudger tool to pry up the top connection of the charging port.
Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
Stop at the next connection.
Use the spudger tool to pry off the long wire connecting the motherboard (top) and the daughter-board (bottom).
Try to use the spudger to pry off as much of the wire as possible before attempting to remove it.
13 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Perfect. How can change de microphone and audio plug?
something?
where can i find the replace of the motherboard?
hi,
where the wifi antena location?
