Giriş
If your phone is not switching on, you may be required to replace the motherboard. This guide will help you do so.
Neye ihtiyacın var
Make sure that your phone is turned off before proceeding
Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
Find and carefully remove all 6 rubber screw covers with the tweezers.
Unscrew all 18 screws from the mid frame.
Using the spudger tool, pry the battery up from the adhesive.
Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
The battery connection was under a black tape in my phone. Remove the tape strip first.
Removing the battery was really difficult. I had to apply a lot of force. You think something is going to break, but it eventually comes loose.
Followed the procedure and all worked as expected. Thanks for this tutorial.
Use the spudger tool to pry off the connections at the bottom-right of the front-facing camera.
Be sure to disconnect both connections before attempting to lift off the wiring.
Use the spudger tool to pry up the top connection of the charging port.
Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
Stop at the next connection.
Use the spudger tool to pry off the long wire connecting the motherboard (top) and the daughter-board (bottom).
Try to use the spudger to pry off as much of the wire as possible before attempting to remove it.
13 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Perfect. How can change de microphone and audio plug?
something?
where can i find the replace of the motherboard?
hi,
where the wifi antena location?
