Ana içeriğe geç
OnePlus 5 Fingerprint Scanner Replacement
Neye ihtiyacın var
  1. OnePlus 5 Fingerprint Scanner Replacement, SIM Card Tray: adım 1, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement, SIM Card Tray: adım 1, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement, SIM Card Tray: adım 1, 3 resimden 3.
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
    • Press firmly to eject the tray.
    • During reassembly, be sure to properly orient the SIM tray you you insert it.
  2. OnePlus 5 Fingerprint Scanner Replacement, Back Cover: adım 2, 1 resimden 1.
    • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
  3. OnePlus 5 Fingerprint Scanner Replacement: adım 3, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 3, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement: adım 3, 3 resimden 3.
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the body and the screen of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
    • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
  4. OnePlus 5 Fingerprint Scanner Replacement: adım 4, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 4, 2 resimden 2.
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
  5. OnePlus 5 Fingerprint Scanner Replacement: adım 5, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 5, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement: adım 5, 3 resimden 3.
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
  6. OnePlus 5 Fingerprint Scanner Replacement: adım 6, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 6, 2 resimden 2.
    • Lever the opening tool to release the first clip from the frame.
  7. OnePlus 5 Fingerprint Scanner Replacement: adım 7, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 7, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement: adım 7, 3 resimden 3.
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
  8. OnePlus 5 Fingerprint Scanner Replacement: adım 8, 1 resimden 1.
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
  9. OnePlus 5 Fingerprint Scanner Replacement: adım 9, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 9, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement: adım 9, 3 resimden 3.
    • With all the clips released, flip the phone over so that the display is face-down.
    • Swing the back cover around and rest it on top of the exposed frame.
    • Be careful not to stress the flex cable connecting the back cover and the frame.
  10. OnePlus 5 Fingerprint Scanner Replacement: adım 10, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 10, 2 resimden 2.
    • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
    • Lift up and remove the cable bracket.
    • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
  11. OnePlus 5 Fingerprint Scanner Replacement: adım 11, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 11, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  12. OnePlus 5 Fingerprint Scanner Replacement: adım 12, 1 resimden 1.
    • Remove the back cover.
  13. OnePlus 5 Fingerprint Scanner Replacement, OnePlus 5 Battery Disconnect: adım 13, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement, OnePlus 5 Battery Disconnect: adım 13, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
  14. OnePlus 5 Fingerprint Scanner Replacement, Loudspeaker: adım 14, 1 resimden 1.
    • Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
  15. OnePlus 5 Fingerprint Scanner Replacement: adım 15, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 15, 2 resimden 2.
    • Insert the flat end of a spudger into the corner of the loudspeaker assembly and pry slightly, loosening the loudspeaker from its recess.
  16. OnePlus 5 Fingerprint Scanner Replacement: adım 16, 1 resimden 1.
    • Remove the loudspeaker.
    • To reinstall the loudspeaker, align the loudspeaker's bottom edge to the frame, then press the assembly into place.
    • During reinstallation, make sure that the display cable connector under the loudspeaker assembly is still securely fastened.
  17. OnePlus 5 Fingerprint Scanner Replacement, OnePlus 5 Interconnect Cable Disconnect: adım 17, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement, OnePlus 5 Interconnect Cable Disconnect: adım 17, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement, OnePlus 5 Interconnect Cable Disconnect: adım 17, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
    • If you are replacing the battery, bend the interconnect flex cable away from the phone and secure it out of the way with a rubber band or tape.
  18. OnePlus 5 Fingerprint Scanner Replacement, Daughterboard: adım 18, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement, Daughterboard: adım 18, 2 resimden 2.
    • Use the point of a spudger the pry up and disconnect the fingerprint scanner connector from its socket on the daughterboard.
  19. OnePlus 5 Fingerprint Scanner Replacement: adım 19, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 19, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement: adım 19, 3 resimden 3.
    • Slip the point of a spudger underneath the antenna interconnect cable and pry up to disconnect it from its socket on the daughterboard.
    • De-route the antenna interconnect cable out of the way of the daughterboard.
  20. OnePlus 5 Fingerprint Scanner Replacement: adım 20, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 20, 2 resimden 2.
    • Insert the edge of a flat end of the spudger underneath the microphone board and twist slightly to release the board's adhesive.
  21. OnePlus 5 Fingerprint Scanner Replacement: adım 21, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 21, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement: adım 21, 3 resimden 3.
    • Slide the flat end of a spudger or the point of an opening pick underneath the daughterboard near its right edge.
    • Gently pry to loosen the daughterboard from its recess.
    • If the daughterboard begins to bend significantly, stop and pry from a different angle.
  22. OnePlus 5 Fingerprint Scanner Replacement: adım 22, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 22, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement: adım 22, 3 resimden 3.
    • Insert the flat end of a spudger underneath the daughterboard, this time approaching it from the bottom.
    • Twist and slide the spudger slightly to release the daughterboard from its recess.
  23. OnePlus 5 Fingerprint Scanner Replacement: adım 23, 1 resimden 1.
  24. OnePlus 5 Fingerprint Scanner Replacement, Fingerprint Scanner: adım 24, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement, Fingerprint Scanner: adım 24, 2 resimden 2.
    Bu adımda kullanılan alet:
    Electrical Tape in 6 Assorted Colors
    $7.99
    Satın Al
    • Slide the flat end of a spudger underneath the tape covering the fingerprint scanner.
    • Lift up to pry and remove the tape.
    • You will most likely not be able to reuse the tape during reinstallation. Replace it with a piece of electrical tape.
  25. OnePlus 5 Fingerprint Scanner Replacement: adım 25, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 25, 2 resimden 2.
    • If you are planning to reuse the fingerprint scanner, be extremely careful pulling the flex cable up. It is very delicate and prone to breaking.
    • Use your finger to gently lift up the connector end of the fingerprint scanner. Pull upwards slowly. Do not pull directly away from the fingerprint scanner.
    • Keep pulling upwards until the fingerprint scanner cable is freed from its recess.
  26. OnePlus 5 Fingerprint Scanner Replacement: adım 26, 3 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 26, 3 resimden 2. OnePlus 5 Fingerprint Scanner Replacement: adım 26, 3 resimden 3.
    • Insert the point of a spudger into the marked areas on either side of the flex cable, and push until the fingerprint scanner is loosened from its recess.
    • Do not apply pressure directly onto the delicate flex cable.
    • If the fingerprint scanner is not coming loose, make sure you are pressing the spudger's point against the backside of the scanner as indicated in the first image, and not the metal plate below it.
  27. OnePlus 5 Fingerprint Scanner Replacement: adım 27, 2 resimden 1. OnePlus 5 Fingerprint Scanner Replacement: adım 27, 2 resimden 2.
    • Once the fingerprint scanner is loosened from its recess, carefully thread its flex cable through the cutout, out of the front of the display.
    • Remove the fingerprint scanner.
    • If you are installing the fingerprint scanner onto a replacement frame, be sure to peel off the blue adhesive liner for the fingerprint scanner before sticking it in place.
Sonuç
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
Bir başkası bu kılavuzu tamamladı.
Arthur Shi
254.151 İtibar
529 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.299 adet Kılavuz yazıldı
8 Yorum
Is there an extra step involved so that the button stays countersunk in the new display? Mine seems to be slightly proud of the screen
John O Shea - Yanıt
Hi John,
If you may need to apply some new adhesive to the underside of the fingerprint sensor to hold it in place.
Arthur Shi -
Hi,
I change the fingerprint but only works if don’t close the back cover, when I close the back cover the OS don’t detect the fingerprint sensor. Any idea?
César Gutiérrez - Yanıt
Hey César,
It may be that something is shorting the fingerprint sensor. Did you replace the tape in step 24 with electrical tape?
Arthur Shi -
Great news, finally I found the problem, the connector from daughter board to motherboard was disconnected but a lot of pins maked contact and the micro, and other electronics works but not the fingerprint sensor. I dissasembled the motherboard and pushed the connector from the flex cable to the socket, now all is working ok. Thanks for the response Arthur!
César Gutiérrez -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 55
Her zaman: 6,408
