Ana içeriğe geç
OnePlus 6 Front Facing Camera Replacement
Neye ihtiyacın var
  1. OnePlus 6 Front Facing Camera Replacement, Front Facing Camera: adım 1, 2 resimden 1. OnePlus 6 Front Facing Camera Replacement, Front Facing Camera: adım 1, 2 resimden 2.
    • Use a heat gun to gently heat the back edges of the phone to loosen the adhesive.
    • Use a plastic opening tool to pry the back cover up.
    • Start from one of the left corners and work your way around the phone using the plastic opening tool.
    • Carefully lift the back cover off.
    • Be careful not to damage or unseat the camera cable while removing the back cover.
  2. OnePlus 6 Front Facing Camera Replacement: adım 2, 2 resimden 1. OnePlus 6 Front Facing Camera Replacement: adım 2, 2 resimden 2.
    • Use tweezers to disconnect the red pull-away tab up from the motherboard.
    • Detach the orange camera ribbon cable, below the red tab, using the tweezers.
    • Grip the green tab and lift the battery up and out of the chassis.
  3. OnePlus 6 Front Facing Camera Replacement: adım 3, 2 resimden 1. OnePlus 6 Front Facing Camera Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the ten screws from the motherboard harness.
    • Pull the motherboard harness up using the tweezers
  4. OnePlus 6 Front Facing Camera Replacement: adım 4, 2 resimden 1. OnePlus 6 Front Facing Camera Replacement: adım 4, 2 resimden 2.
    • Use the pointed tip of a spudger to lift the front-facing camera's pin connection, gently prying on the plug vertically until it completely releases.
    • Lift the front-facing camera up and out using tweezers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 54
Her zaman: 509
