Ana içeriğe geç
OnePlus 6T Front Camera Replacement
Neye ihtiyacın var
  1. OnePlus 6T Front Camera Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    FixBot'a Sor
    Yorum Ekle
  2. OnePlus 6T Front Camera Replacement: adım 2, 1 resimden 1.
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    FixBot'a Sor
    Yorum Ekle
  3. OnePlus 6T Front Camera Replacement: adım 3, 1 resimden 1.
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. OnePlus 6T Front Camera Replacement: adım 4, 3 resimden 1. OnePlus 6T Front Camera Replacement: adım 4, 3 resimden 2. OnePlus 6T Front Camera Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    FixBot'a Sor
    Yorum Ekle
  5. OnePlus 6T Front Camera Replacement, Front Camera: adım 5, 2 resimden 1. OnePlus 6T Front Camera Replacement, Front Camera: adım 5, 2 resimden 2.
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
    FixBot'a Sor
    Yorum Ekle
  6. OnePlus 6T Front Camera Replacement: adım 6, 1 resimden 1.
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
    FixBot'a Sor
    Yorum Ekle
  7. OnePlus 6T Front Camera Replacement: adım 7, 1 resimden 1.
    • Using a spudger, gently remove the midframe and place it to the side.
    FixBot'a Sor
    Yorum Ekle
  8. OnePlus 6T Front Camera Replacement: adım 8, 1 resimden 1.
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kristen Gismondi
107.689 İtibar
270 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
27.554 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 55
Her zaman: 1,777
