Ana içeriğe geç
OnePlus 6T Rear Camera Replacement
Neye ihtiyacın var
    1. OnePlus 6T Rear Camera Replacement, Back Cover: adım 1, 1 resimden 1.
      • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 6T Rear Camera Replacement: adım 2, 1 resimden 1.
      • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
      • Carefully remove the SIM card from its tray.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 6T Rear Camera Replacement: adım 3, 1 resimden 1.
      • Loosen the binding glue within the phone using a hairdryer or an iOpener.
      • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus 6T Rear Camera Replacement: adım 4, 3 resimden 1. OnePlus 6T Rear Camera Replacement: adım 4, 3 resimden 2. OnePlus 6T Rear Camera Replacement: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
      • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
      • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
      • Remove the back cover from the phone.
      • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 6T Rear Camera Replacement, Front Camera: adım 5, 2 resimden 1. OnePlus 6T Rear Camera Replacement, Front Camera: adım 5, 2 resimden 2.
      • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
      • Use tweezers to remove the battery cover and place it to the side.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 6T Rear Camera Replacement: adım 6, 1 resimden 1.
      • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 6T Rear Camera Replacement: adım 7, 1 resimden 1.
      • Using a spudger, gently remove the midframe and place it to the side.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus 6T Rear Camera Replacement: adım 8, 1 resimden 1.
      • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
      • Remove the front camera from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 6T Rear Camera Replacement, Motherboard: adım 9, 2 resimden 1. OnePlus 6T Rear Camera Replacement, Motherboard: adım 9, 2 resimden 2.
      • Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 6T Rear Camera Replacement: adım 10, 1 resimden 1.
      • Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 6T Rear Camera Replacement: adım 11, 1 resimden 1.
      • Use a spudger to disconnect the signal cables on the right side of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus 6T Rear Camera Replacement: adım 12, 2 resimden 1. OnePlus 6T Rear Camera Replacement: adım 12, 2 resimden 2.
      • Disconnect the slider from the top of the phone with a spudger.
      • The slider is extremely delicate, so it is important you do not attempt to remove it from the sides.
      • Gently pull the motherboard from the left side and remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 6T Rear Camera Replacement, Rear Camera: adım 13, 2 resimden 1. OnePlus 6T Rear Camera Replacement, Rear Camera: adım 13, 2 resimden 2.
      • Using a spudger, disconnect the two metal rear camera tabs on the left side of the camera.
      • Remove the camera from its slot on the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
In step 6 the screw under the humidity sensor is not shown. this needs to be removed as well
W W - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 1,894
