Ana içeriğe geç
OnePlus 7 Pro Battery Replacement
Neye ihtiyacın var
    1. OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: adım 1, 3 resimden 1. OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: adım 1, 3 resimden 2. OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: adım 1, 3 resimden 3.
      • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
      • Press gently to eject the SIM tray.
      • Remove the SIM card tray from the device.
      • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 7 Pro Battery Replacement: adım 2, 2 resimden 1. OnePlus 7 Pro Battery Replacement: adım 2, 2 resimden 2.
      • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
      • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
      • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
      • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 7 Pro Battery Replacement: adım 3, 3 resimden 1. OnePlus 7 Pro Battery Replacement: adım 3, 3 resimden 2. OnePlus 7 Pro Battery Replacement: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
      • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus 7 Pro Battery Replacement: adım 4, 3 resimden 1. OnePlus 7 Pro Battery Replacement: adım 4, 3 resimden 2. OnePlus 7 Pro Battery Replacement: adım 4, 3 resimden 3.
      • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
      FixBot'a Sor
      Yorum Ekle
    5. OnePlus 7 Pro Battery Replacement: adım 5, 2 resimden 1. OnePlus 7 Pro Battery Replacement: adım 5, 2 resimden 2.
      • Remove the phone's back cover.
      • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
      FixBot'a Sor
      Yorum Ekle
    6. OnePlus 7 Pro Battery Replacement: adım 6, 3 resimden 1. OnePlus 7 Pro Battery Replacement: adım 6, 3 resimden 2. OnePlus 7 Pro Battery Replacement: adım 6, 3 resimden 3.
      • Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
      • Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
      FixBot'a Sor
      Yorum Ekle
    7. OnePlus 7 Pro Battery Replacement: adım 7, 1 resimden 1.
      • Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
      FixBot'a Sor
      Yorum Ekle
    8. OnePlus 7 Pro Battery Replacement: adım 8, 2 resimden 1. OnePlus 7 Pro Battery Replacement: adım 8, 2 resimden 2.
      • Peel off the adhesive cover for the new battery cover.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus 7 Pro Battery Replacement, Remove upper plate: adım 9, 1 resimden 1.
      • Remove all 14 screws of the upper plate.
      • As soon as all screws are removed, you can take it off with a spudger.
      • One screw is placed underneath a white sticker. You can punch through the sticker with your screwdriver.
      • All of the screws are the same length, and can be removed with a PH00 bit.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 7 Pro Battery Replacement, Disconnect Battery: adım 10, 1 resimden 1.
      • Disconnect the battery connector with a spudger.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 7 Pro Battery Replacement: adım 11, 2 resimden 1. OnePlus 7 Pro Battery Replacement: adım 11, 2 resimden 2.
      • Grab the tab and gently pull the Battery out.
      • The Battery is glued on the bottom side.
      FixBot'a Sor
      Yorum Ekle
      • After installing the new battery and reassembling your device, calibration is highly recommended. To calibrate the battery, charge the phone to full and allow it to continue charging uninterrupted for 2 hours, let the battery drain fully, and charge it to full without interruption one last time.
      • This step helps the phone recognize the new battery and to determine its' maximum capacity.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, replace the battery cover and follow these instructions in reverse order.
24 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Fabian Jung
829 İtibar
1 Kılavuz yazıldı
10Kılavuz Yorumları
It didnt mention how to open the back cover in the first place? Which is the hardest part and the one that require the most skills and specialized tools.
Abdulaziz Alsaqer - Yanıt Paylaş
The article links another article talking about the cover. Both do not cover how to apply the new part, specifically, how to install the new battery in this case. I think vitally important. :) @fabianjung
Chintan Pathak - Yanıt Paylaş
DO NOT use the jimmy tool or anything metal to scrape the glue off!!! You will scratch and remove the paint on the back cover!
Dani - Yanıt Paylaş
5/10 as a guide IMHO.
Why isn't a replacement adhesive gasket part of the requirements (in addition to the replacement battery)??!
The seal will most likely be severely compromised after being opened.
JayM - Yanıt Paylaş
Update: 7/10. Taking the back off went easily/smoothly after lying on a 3D printer bed (@80C) for about 10mins, then using a hot air gun (@90C) and a metal spudger and plastic picks to gently break the adhesive holding the back to the body.
No issue removing the inside cover and pulling out the battery.
Having a replacement adhesive gasket/tape is a good idea when re-assembling though. The original guide didn't mentioned this.
JayM - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 29
Son 7 gün: 134
Son 30 gün: 538
Her zaman: 47,316
