Ana içeriğe geç
OnePlus 7T Battery Cover Replacement
Neye ihtiyacın var
Videoya Genel Bakış
    1. OnePlus 7T  Battery Cover Replacement, OnePlus 7T  Battery Cover Replacement: adım 1, 3 resimden 1. OnePlus 7T  Battery Cover Replacement, OnePlus 7T  Battery Cover Replacement: adım 1, 3 resimden 2. OnePlus 7T  Battery Cover Replacement, OnePlus 7T  Battery Cover Replacement: adım 1, 3 resimden 3.
      • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
      • Press gently to eject the SIM tray.
      • Remove the SIM card tray from the device.
      • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 7T  Battery Cover Replacement: adım 2, 2 resimden 1. OnePlus 7T  Battery Cover Replacement: adım 2, 2 resimden 2.
      • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
      • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
      • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
      • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 7T  Battery Cover Replacement: adım 3, 3 resimden 1. OnePlus 7T  Battery Cover Replacement: adım 3, 3 resimden 2. OnePlus 7T  Battery Cover Replacement: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
      • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus 7T  Battery Cover Replacement: adım 4, 2 resimden 1. OnePlus 7T  Battery Cover Replacement: adım 4, 2 resimden 2.
      • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
      FixBot'a Sor
      Yorum Ekle
    5. OnePlus 7T  Battery Cover Replacement: adım 5, 3 resimden 1. OnePlus 7T  Battery Cover Replacement: adım 5, 3 resimden 2. OnePlus 7T  Battery Cover Replacement: adım 5, 3 resimden 3.
      • Remove the phone's back cover.
      • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
      FixBot'a Sor
      Yorum Ekle
    6. OnePlus 7T  Battery Cover Replacement: adım 6, 2 resimden 1. OnePlus 7T  Battery Cover Replacement: adım 6, 2 resimden 2.
      • Replace the battery cover adhesive.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Selena
2.968 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 46
Her zaman: 3,352
