Ana içeriğe geç
OnePlus 8 Pro Battery Replacement
Neye ihtiyacın var
    1. OnePlus 8 Pro Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Heat up the back edge of the phone with the iOpener / any HotPack.
      • Start with a long edge as it is easier to open the back cover in the next step.
      • You may also use a hair dryer or heat gun to heat the adhesive.
      • Be careful not to overheat the phone - the screen and internal battery are susceptible to heat damage.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus 8 Pro Battery Replacement: adım 2, 1 resimden 1.
      • Insert the opening pick in the middle of the phone where you heated it. Slide it along the edge to cut through the adhesive.
      • This can be a bit tricky, don't use any sharp objects as you can damage the case. It's reccomended that you use a plastic wedge tool such as the one by iFixit, as it has a thicker ledge to prevent you from slicing too far in.
      • If it does not work, try heating the edge again.
      • Don't insert the opening pick too far. There are no flex cables in the way, but the wireless charging coil could be damaged.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus 8 Pro Battery Replacement: adım 3, 2 resimden 1. OnePlus 8 Pro Battery Replacement: adım 3, 2 resimden 2.
      • Leave the opening picks once you managed to open one side.
      • Use heat on the next edge to open it.
      • Repeat steps 2 and 3 for all four edges.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus 8 Pro Battery Replacement: adım 4, 1 resimden 1.
      • Remove these screws (Phillips 00).
      • Remove this Phillips 00 screw. You can remove the white paper with tweezers or just push the screwdriver through the paper.
      FixBot'a Sor
      Yorum Ekle
    5. OnePlus 8 Pro Battery Replacement: adım 5, 2 resimden 1. OnePlus 8 Pro Battery Replacement: adım 5, 2 resimden 2.
      • Carefully lift the two stickers which hold the wireless charging coil down.
      FixBot'a Sor
      Yorum Ekle
    6. OnePlus 8 Pro Battery Replacement: adım 6, 1 resimden 1.
      • Lift the charging coil.
      • Remove the two Phillips 00 screws below the coil.
      FixBot'a Sor
      Yorum Ekle
    7. OnePlus 8 Pro Battery Replacement: adım 7, 1 resimden 1.
      • Remove the top cover / coil assembly.
      FixBot'a Sor
      Yorum Ekle
    8. OnePlus 8 Pro Battery Replacement: adım 8, 1 resimden 1.
      • Disconnect the battery.
      FixBot'a Sor
      Yorum Ekle
    9. OnePlus 8 Pro Battery Replacement: adım 9, 1 resimden 1.
      • Pull the red pulling tab away from the battery.
      • Separate the red pulling tab from the black adhesive.
      • After separating, hold the black adhesive down and pull the red tab up vertically to remove the battery.
      • Make sure not to bend the battery too heavily.
      FixBot'a Sor
      Yorum Ekle
    10. OnePlus 8 Pro Battery Replacement: adım 10, 2 resimden 1. OnePlus 8 Pro Battery Replacement: adım 10, 2 resimden 2.
      • Remove the red pulling tab from the old battery and stick it on the under side of the new battery.
      • This makes it easier to replace the battery again.
      • Insert the new battery.
      • Wrap the black adhesive strips on both sides around the battery to secure it.
      FixBot'a Sor
      Yorum Ekle
    11. OnePlus 8 Pro Battery Replacement: adım 11, 1 resimden 1.
      • Remove the old adhesive and replace it with new adhesive strips.
      • Reverse from step 8 to assemble the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Manuel Graf
220 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
be carefull: the adhesives of the back cover are not only on the edge, but also on the 4 corners (see the back cover on photo of step 4). You should carefully cut these off from the short edges, BEFORE trying to lift the cover.
LeFils - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 33
Son 30 gün: 186
Her zaman: 3,043
