Ana içeriğe geç
OnePlus Nord N200 Sub Board Replacement
Neye ihtiyacın var
  1. OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: adım 1, 3 resimden 1. OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: adım 1, 3 resimden 2. OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: adım 1, 3 resimden 3.
    • Take sim tray out prior to beginning repair.
    • Heat back of phone to make the adhesion more pliable
    • Insert a slim prying tool to begin removing the back cover, move in a counterclockwise direction
    • Add IPA as you work to detatch the adhesion layer
    • When approaching the volume button, be cautious, as the ribbon cable is exposed and can easilyt be cut
    • Remove back cover
  2. OnePlus Nord N200 Sub Board Replacement: adım 2, 3 resimden 1. OnePlus Nord N200 Sub Board Replacement: adım 2, 3 resimden 2. OnePlus Nord N200 Sub Board Replacement: adım 2, 3 resimden 3.
    • Using a J000 screwdriver, remove the Screws holding the edge casing to the screen (19 Total)
    • Using a pry tool, seperate the edge plastic from the screen
    • Once you have attained suitable lift, disconnect the power button cable.
    • Remove the edge plastic and set aside.
  3. OnePlus Nord N200 Sub Board Replacement: adım 3, 1 resimden 1.
    • Remove the plastic speaker piece
    • Disconnect the antenna cables and main board connector
    • Remove the board and insert new component
    • reconnect connectors
  4. OnePlus Nord N200 Sub Board Replacement: adım 4, 3 resimden 1. OnePlus Nord N200 Sub Board Replacement: adım 4, 3 resimden 2. OnePlus Nord N200 Sub Board Replacement: adım 4, 3 resimden 3.
    • Reconnect the antenna and main board
    • Reconnect the power cable, and reattach the plastic edge
    • Using J000, screw the 19 screws back in
  5. OnePlus Nord N200 Sub Board Replacement: adım 5, 2 resimden 1. OnePlus Nord N200 Sub Board Replacement: adım 5, 2 resimden 2.
    • Reconnect the back plastic, and set on heat to adhere
    • You can also use tesa tape to increase the adhesion.
Sonuç
This order can be used for charger, headphone jack, or water damage to sub board.
Jesse Smith
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 41
Her zaman: 1,060
