Ana içeriğe geç
OnePlus One Micro USB Port Replacement
Neye ihtiyacın var
  1. OnePlus One Micro USB Port Replacement, Battery: adım 1, 3 resimden 1. OnePlus One Micro USB Port Replacement, Battery: adım 1, 3 resimden 2. OnePlus One Micro USB Port Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the SIM tray.
    • Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
    • You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
    • Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
    • It is of utmost importance that you do not attempt to free the battery from the device at this point without proceeding to the following step! This is an integrated battery that can easily be damaged or destroyed if the proper steps are are not taken.
    It doesn't mention you have to remove SIM tray first.
    pawel - Yanıt
    I used the #0 for the rear panel screws. The #00 is too small and will slip, stripping the screws if you're not extra careful.
    anonymous 2668 - Yanıt
    where can i buy the battery??
    Shaun Davis - Yanıt
    Has anyone answered this? I am looking too.
    Elie Daou -
    They sell it on here, although I found mine on eBay.
    Roger -
    Aliexpress for $9 (original)
    David van Ballegooijen -
    The last three hidden screws are a !&&* of a time consumer to remove. probably you would need only a certain type of tweezers - I got stuck at midway and now I cannot get go have my phone detect the sim card either probably because the six screws are removed. I can now turn the phone back on but with no service or wifi connections are detected. This phone is a disaster!
    Manan Shah - Yanıt
    Ivdid that too but son in law found I had reinstalled sim card in backwards or upside down.
    wildcat75666 -
    Where did you buy the micro USB piece? Thanks a lot!
    Davide Rota - Yanıt
    EBay. I bought new battery cause old ibe was dead would not charge. Just ordered new cables fit 9.00 something free shipping. Anyway hope this fixes problem cause new battery did not fix problems.
    wildcat75666 -
    I was able to open going from the microusb slot and working my way around. The corners are tough, though.
    Roger - Yanıt
    in my phone the battery was glued with double sided adhesive tape, only on the right side. I pried the left side up first, and carefully removed the battery. to lift the battery I used first used a suction cup(?) followed by a plectrum like tool to lift te battery, and keep it lifted
    Eelco Busch - Yanıt
    A word of caution: the back panel is harder to remove than you might think. Especially because you may be removing the *screen* by mistake. When you have a "grip" with the tool make sure the metallic border is not coming off with it, and when you have removed enough to be able to lift the panel, make sure it isn't attached by ribbons - in that case you've been removing the screen. A good idea is to gently press your finger nail against the weak plastic located between the back and the SIM slot, and going up and down and sideways until you hear a click. Then you can start from there with the opening tool. As recommended be very gentle around the SIM slot.
    Menahem Julien Raccah Lisei - Yanıt
    Where do I get the plastic opening tool?
    Julie Hejducek - Yanıt
  2. OnePlus One Micro USB Port Replacement: adım 2, 3 resimden 1. OnePlus One Micro USB Port Replacement: adım 2, 3 resimden 2. OnePlus One Micro USB Port Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, remove the plastic plugs.
    • Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
    • Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
    The plugs are annoying to open for the first time. They're shaped like little pegs, but I was able to poke at them with screwdrivers enough to open.
    Roger - Yanıt
    the best spot to start prying the cover open is at the cable outlet for the power/volume buttons (careful not to dameage the wires)
    Marius137 - Yanıt
    A needle works best to remove the plugs.
    Stan Barton - Yanıt
    I second this. I used a sewing pin and the plugs came out in no time!
    Liam Ong -
    Be careful not to displace the rear camera when replacing the motherboard cover.
    Liam Ong - Yanıt
    when I lifted the motherboard cover the battery cable stuck on it so that I lifted both, the plastic cover and the cable - step 4 below was not necessary to perform. Be careful!
    Rene Hommel - Yanıt
    anyone know what is the 6 orange screws in step 2 are called?
    e.g. M2 x 2
    I lost some screws.
    So where can I buy some replacement of these screws?
    Tyler Durden - Yanıt
  3. OnePlus One Micro USB Port Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
    At the top right of your device you see a white dot. That white dot is the warranty sticker. You need to take off that sticker in order to get to the screw that lies underneath. Then unscrew that screw. Otherwise you will not be able to pry off this cover.
    Anke - Yanıt
  4. OnePlus One Micro USB Port Replacement: adım 4, 3 resimden 1. OnePlus One Micro USB Port Replacement: adım 4, 3 resimden 2. OnePlus One Micro USB Port Replacement: adım 4, 3 resimden 3.
    • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
    • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
    • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
    This took a ton of force to remove from the adhesive!
    Also I was able to take off the cable before removing the battery.
    Roger - Yanıt
    Is it OK to use the battery if I bent it during removal? I had to 'iron' it flat, but I think it might still be useable...
    Henry Annand - Yanıt
    the best way to remove the battery is to lever the left side up from the bottom and remove it from the glue with an old credit card
    Marius137 - Yanıt
    Do this! it comes up very easily this way. All the adhesive is on the right side.
    Daniel ONeill -
    Great suggestion with a card to remove the battery!
    Jeff Mack -
    Thanks for this trick saved me a lot of time
    George P -
    I second Dangerous Picture's suggestion. I found it very helpful to remove the ribbon from the dock (it was easy to do) before trying to remove the battery.
    Stan Barton - Yanıt
    on my phone extensive use of glue was concentrated on just one side (right hand side). Not impossible to remove, little tricky
    Rene Hommel - Yanıt
    I mistakenly removed the battery with force, and the back peeled and brought out smoke, seemingly like it's gonna explode. Help !!!
    warys Moreno - Yanıt
    Hola, después de cambiar la batería el telefono creo que sigue identificando que está gastada porque me dura igual que antes- He intentado un código de reteseteo pero me da error. Hay alguna forma de resetear la batería? el mío es el modelo 9 pro
    María Torres - Yanıt
  5. OnePlus One Micro USB Port Replacement: adım 5, 3 resimden 1. OnePlus One Micro USB Port Replacement: adım 5, 3 resimden 2. OnePlus One Micro USB Port Replacement: adım 5, 3 resimden 3.
    • Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
    • You can disconnect the battery before freeing it to make removal easier.
    For step 4, the connection to the battery should always be done as soon as possible so after removing the back plate to the board would be ideal.
    Otherwise, very thorough so far!
    Duc - Yanıt
    Thought I was going to snap my battery in half but patience and slight pressure did the trick.
    Also agreeing the battery should be disconnected as soon as possible.
    Rasmus Beck - Yanıt
    From where do I procure a new battery for it?????????
    Roderick Edric Chandra - Yanıt
    très bon tuto ,aucun problème si vous suivez la procédure ,bravo et merci
    antoine v - Yanıt
    There are several connectors to the motherboard. In the picture above, one connector above and, below the screw thread, three more connectors. Be careful to reconnect any connectors accidentally disconnected while disconnecting / removeing the battery. In my case the connector shown at the top of the row came unconnected.
    Jörg Thiesemann-Bihn - Yanıt
    salut, pour moi le connecteur à la nappe était collé au cache en plastique qui couvrait la carte mère … mais le reste s’est bien passé.
    Merci pour le tuto !
    Didaf Wazir - Yanıt
    Thanks Buddy, I replaced battery of my one plus one and when I switched it on, touch was not working. It was heart sinking panic moment...Then I came across https://forum.xda-developers.com/oneplus... post, simple trick of sliding piece of paper below battery solved and infact improved the touch response. Thanks !
    Radhakrishna Shetty - Yanıt
    Kifch nikmandha
    asadzoya388 - Yanıt
    When putting in the new battery, the battery ribbon cable did not line up with the dock on the motherboard, on the replacement battery I ordered from iFixIt. I was able to carefully peel back the foil covering ribbon cable, align the cable, then press the foil back in place. Now, everything seems to be working.
    I P - Yanıt
  6. OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: adım 6, 3 resimden 1. OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: adım 6, 3 resimden 2. OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: adım 6, 3 resimden 3.
    • Once the battery has been removed, we shift our attention to the back panel assembly. This piece is held together by six screws. See info note below.
    • Luckily, the OnePlus One was assembled with all of the same size screws save for the one holding down the motherboard. All of these screws are philips 00 and 3.175 mm. in lenght.
    • Using the spudger we pry open the panel assembly and, behold, we have access to the micro usb port. You can also use a blue opening tool if you prefer.
    • Keep in mind that there are two hidden screws. Both are located beneath plastic plugs. Tweezers are an effective tool for removing the plugs.
    on my 1+1, the two screws beneath the gromets, where phillips 000
    Lucid Nonsense - Yanıt
  7. OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: adım 7, 3 resimden 1. OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: adım 7, 3 resimden 2. OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: adım 7, 3 resimden 3.
    • Now that we have access to the usb port, we use the flat end of or spudger and lift it off of its connector and free it from the daughterboard.
  8. OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: adım 8, 3 resimden 1. OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: adım 8, 3 resimden 2. OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: adım 8, 3 resimden 3.
    • Now it is time to remove the ribbon. You will notice that there is a small strip of black tape keeping us from from completely freeing it. Not to worry. Simply use the spudger to maneuver the tape out of the way.
    • Your micro USB and attached ribbon are now free to be removed.
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
Chad Jackson
5.370 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Brown Fall 2014 USF Tampa, Team 3-3, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G3
3 Üyeler
20 adet Kılavuz yazıldı
4Kılavuz Yorumları
Thanks back up and working should get a few more years out of it
cheers
robert storrs - Yanıt
Pretty easy, just be really careful when removing battery from glue ;)
Thanks a lot for this guide which is really complete !
Gael Augeat - Yanıt
I was able to successfully follow these instructions. Pretty sure I damaged the battery during removal though. I intended to replace the battery anyways, so I’m not too worried about it, but it would be nice to to have some technique listed for removing it less destructively.
George Simpson - Yanıt
For me USB was not charging because it seems that one of the 2 USB plugs above the battery were loose. I did replace the battery already sometime far in the past so this might have been the cause. If you just want to re-plug on the upper side and lift the port on the lower side, you don't even need to remove the battery. Just make sure that all plugs, not just USB, are tight before screwing everything back together.
Thanks a lot for this guide!
Robert Gutjahr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 120
Her zaman: 37,392
