Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
As great as the OnePlus X is, it is not indestructible. If a heartbreaking (or glass-breaking) fall occurs, use this guide to remove the rear panel.
Neye ihtiyacın var
Power off the device with the Power Button, located on the right hand side of the phone (smaller button).
Hold the button down for a few seconds, until the option "Power Off" appears.
Tap "Power Off" on the screen to power down the phone.
Using a heat gun, slowly and evenly heat the edges of the rear panel.
While heating the rear panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the rear panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the panel.
8 farklı kişi bu kılavuzu tamamladı.
4 Yorum
where can i buy the adhesive to stick it back or reuse the adhesive and reheat it up
How much cost to change one plus x back cover
How do you attach the new panel back?
well, this is not an “exchange”, but rather only a “removal” guide… please don’t mislead your readers and search results.
