Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The battery of the OnePlus X is located behind the glass rear panel. Use this guide to remove the battery and disconnect it from the motherboard.
Neye ihtiyacın var
Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
Select "Power Off" on the screen to turn off the phone.
Using a heat gun, apply slow and even heat to the edges of the back panel.
While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the back panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the back panel.
Using a PH000 screwdriver, remove the following seven screws:
Four (longer) Phillips 000 screws
Three shorter Phillips 000 screws
Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
There are two clips near the bottom, right above that battery, so start by prying on the bottom edge of the plate.
27 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Thanks! This is cool! I didn't know I can replace my OnePlus X's battery :)
how to stick back panel to the device again?
Double sided adhesive
Does someone know a good vendor for a new Battery for the OPX that sells in europ? I also want to change the battery after 2 1/2 years.
Thanks in advance =)
I just bought this :-) https://www.ebay.de/itm/382548678130
