Ana içeriğe geç
Oontz Angle 3 ULTRA Back Panel Replacement
Neye ihtiyacın var
  1. Oontz Angle 3 ULTRA Back Panel Replacement, Back Panel: adım 1, 3 resimden 1. Oontz Angle 3 ULTRA Back Panel Replacement, Back Panel: adım 1, 3 resimden 2. Oontz Angle 3 ULTRA Back Panel Replacement, Back Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Back Panel Replacement: adım 2, 3 resimden 1. Oontz Angle 3 ULTRA Back Panel Replacement: adım 2, 3 resimden 2. Oontz Angle 3 ULTRA Back Panel Replacement: adım 2, 3 resimden 3.
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Back Panel Replacement: adım 3, 3 resimden 1. Oontz Angle 3 ULTRA Back Panel Replacement: adım 3, 3 resimden 2. Oontz Angle 3 ULTRA Back Panel Replacement: adım 3, 3 resimden 3.
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Back Panel Replacement: adım 4, 3 resimden 1. Oontz Angle 3 ULTRA Back Panel Replacement: adım 4, 3 resimden 2. Oontz Angle 3 ULTRA Back Panel Replacement: adım 4, 3 resimden 3.
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 760
