Giriş
If you want to access internal components such as the pump or the heater, you have to open the machine. This is shown here.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Remove all attachments such as water tank, pomace container, brew group, drip tray.
Remove all coffee beans.
Remove the cover from the coffee spout. Lift them from bottom to top, using only plastic tools to pry.
Using a Torx T10 screwdriver remove the single screw from the bean container.
Lift the bean container up and remove it.
Slide the cup holder all the way down.
Start to pry off the molded part at the back seam, the catches gradually loosen with a loud crack.
It's a bit tricky to slide the cover over the steam valve knob, you need some strength to do it.
The white magnetic contact (reed contact) for the lid of the bean container is located under the bean container. Lift it up and drop it through the opening in the molding.
Lift up the cover.
The two side parts are attached with a few Torx T10 screws, unscrew them:
A screw at the top back
A screw at the top
Four screws on the front
Remove two screws on the side with the water tank.
The side parts are jammed. Start to pry apart the two side pieces at the back seam.
Pry off the two side parts with a plastic tool. Pay attention to the power connection.
7 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
92%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
5 Yorum
Danke. Hat prima funktioniert.
Perfect immer schön positives Feedback zu bekommen
Jawoll! Freut mich! :-)
VauWeh -
