Ana içeriğe geç
Opening Case
Neye ihtiyacın var
  1. Opening Case, Remove Battery: adım 1, 3 resimden 1. Opening Case, Remove Battery: adım 1, 3 resimden 2. Opening Case, Remove Battery: adım 1, 3 resimden 3.
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
    FixBot'a Sor
  2. Opening Case, Remove Trigger Buttons: adım 2, 2 resimden 1. Opening Case, Remove Trigger Buttons: adım 2, 2 resimden 2.
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
    FixBot'a Sor
  3. Opening Case, Remove Screws: adım 3, 2 resimden 1. Opening Case, Remove Screws: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
    FixBot'a Sor
  4. Opening Case, Unclip Covers: adım 4, 3 resimden 1. Opening Case, Unclip Covers: adım 4, 3 resimden 2. Opening Case, Unclip Covers: adım 4, 3 resimden 3.
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
    FixBot'a Sor
  5. Opening Case, Separate Covers: adım 5, 1 resimden 1.
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
    FixBot'a Sor
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brian W
1.773 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 66
Her zaman: 2,359
