Giriş
For most repairs, you have to open the device. This isn’t a big problem with the EP models.
Note: EP 5xxx models are from an older Saeco line. Compare with Saeco Minuto.
The instructions can also help with Saeco- models and with other fully automatic coffee machines from Philips und Gaggia - the devices all come from the same manufacturer and are very similarly built.
Neye ihtiyacın var
Remove all attachments, like the water reservoir, the brewing chamber, the bean compartment lid, and the drip tray. Remove all of the coffee beans.
Turn the machine around so the back is facing you. Remove the two T10 Torx screws at the bottom edge. Pull out the back at the bottom edge and lift it down.
It's important that the parts are readily visible:
The motherboard
The pump
The flow meter
The heating element
Pull the upper cover out from under the front cover and lay it slightly offset.
Remove both of the T10 Torx screws attached to the side covers.
Picture 2 shows the grinder, which can now be easily taken off.
If you want to repair the grinder: here are the instructions Replacing the Philips ceramic grinder motor and sensor
Complete the steps in reverse order to reassemble your device.
9 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
8Kılavuz Yorumları
Leider stimmt diese Anleitung nicht für alle EP Modelle, ich besitze die Saeco Philips EP5960-10 diese zu öffnen ist eine Katastrophe. Da gibt es keine einzelne Wände, ich muss unbedingt unten an den Stromanschluss, da meine Maschine Plötzlich nicht mehr angeht, eventuell ist da eine Sicherung verbaut. Phillips will 200 € haben, da lege ich 100 drauf dann bekommt man was neues.
Danke für den Hinweis. Diese Modelle gehen auf eine ältere Linie zurück. Vergleiche mit der Saeco Exprelia.
@michaelkollek ... oder Saeco Minuto
