Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Opening Procedure
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Opening Procedure, Opening Procedure: adım 1, 1 resimden 1.
    • Handling it by the tabs on either side, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
  2. Opening Procedure: adım 2, 3 resimden 1. Opening Procedure: adım 2, 3 resimden 2. Opening Procedure: adım 2, 3 resimden 3.
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel assembly from from the rear case.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  3. Opening Procedure: adım 3, 2 resimden 1. Opening Procedure: adım 3, 2 resimden 2.
    • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  4. Opening Procedure: adım 4, 1 resimden 1.
    • Reheat and reapply the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    • Let it rest for a few minutes to reheat the left edge of the iPad.
  5. Opening Procedure: adım 5, 3 resimden 1. Opening Procedure: adım 5, 3 resimden 2. Opening Procedure: adım 5, 3 resimden 3.
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  6. Opening Procedure: adım 6, 3 resimden 1. Opening Procedure: adım 6, 3 resimden 2. Opening Procedure: adım 6, 3 resimden 3.
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  7. Opening Procedure: adım 7, 2 resimden 1. Opening Procedure: adım 7, 2 resimden 2.
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  8. Opening Procedure: adım 8, 1 resimden 1.
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  9. Opening Procedure: adım 9, 3 resimden 1. Opening Procedure: adım 9, 3 resimden 2. Opening Procedure: adım 9, 3 resimden 3.
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  10. Opening Procedure: adım 10, 3 resimden 1. Opening Procedure: adım 10, 3 resimden 2. Opening Procedure: adım 10, 3 resimden 3.
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  11. Opening Procedure: adım 11, 3 resimden 1. Opening Procedure: adım 11, 3 resimden 2. Opening Procedure: adım 11, 3 resimden 3.
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  12. Opening Procedure: adım 12, 2 resimden 1. Opening Procedure: adım 12, 2 resimden 2.
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  13. Opening Procedure: adım 13, 1 resimden 1.
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  14. Opening Procedure: adım 14, 3 resimden 1. Opening Procedure: adım 14, 3 resimden 2. Opening Procedure: adım 14, 3 resimden 3.
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  15. Opening Procedure: adım 15, 3 resimden 1. Opening Procedure: adım 15, 3 resimden 2. Opening Procedure: adım 15, 3 resimden 3.
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  16. Opening Procedure: adım 16, 1 resimden 1.
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  17. Opening Procedure: adım 17, 3 resimden 1. Opening Procedure: adım 17, 3 resimden 2. Opening Procedure: adım 17, 3 resimden 3.
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  18. Opening Procedure: adım 18, 2 resimden 1. Opening Procedure: adım 18, 2 resimden 2.
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  19. Opening Procedure: adım 19, 2 resimden 1. Opening Procedure: adım 19, 2 resimden 2.
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  20. Opening Procedure: adım 20, 2 resimden 1. Opening Procedure: adım 20, 2 resimden 2.
    • Slide the pick around the lower left edge of the iPad.
  21. Opening Procedure: adım 21, 3 resimden 1. Opening Procedure: adım 21, 3 resimden 2. Opening Procedure: adım 21, 3 resimden 3.
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  22. Opening Procedure: adım 22, 3 resimden 1. Opening Procedure: adım 22, 3 resimden 2. Opening Procedure: adım 22, 3 resimden 3.
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
Sonuç
Evan Noronha
223.594 İtibar
168 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 348
