Ana içeriğe geç
Opening the Column in the Hamilton Galileo
Neye ihtiyacın var
  1. Opening the Column in the Hamilton Galileo, Opening the Column in the Hamilton Galileo: adım 1, 1 resimden 1.
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Opening the Column in the Hamilton Galileo: adım 3, 1 resimden 1.
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Opening the Column in the Hamilton Galileo: adım 4, 2 resimden 1. Opening the Column in the Hamilton Galileo: adım 4, 2 resimden 2.
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
Sonuç
Ian Van Sciver
332 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G26, Paton Spring 2020 Cal Poly, Team S7-G26, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G26
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 143
