Ana içeriğe geç
Opening the Galaxy Watch3
Neye ihtiyacın var
  1. Opening the Galaxy Watch3, Unfasten the back cover screws: adım 1, 1 resimden 1.
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Opening the Galaxy Watch3, Wedge open the back cover: adım 2, 2 resimden 1. Opening the Galaxy Watch3, Wedge open the back cover: adım 2, 2 resimden 2.
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Opening the Galaxy Watch3, Disconnect the sensor flex cable: adım 3, 3 resimden 1. Opening the Galaxy Watch3, Disconnect the sensor flex cable: adım 3, 3 resimden 2. Opening the Galaxy Watch3, Disconnect the sensor flex cable: adım 3, 3 resimden 3.
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Opening the Galaxy Watch3, Remove the back cover: adım 4, 2 resimden 1. Opening the Galaxy Watch3, Remove the back cover: adım 4, 2 resimden 2.
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tobias Isakeit
119.540 İtibar
189 adet Kılavuz yazıldı
Ekip
3 Yorum
where can I get the galaxy watch3 rubber gasket?
regards
Miguel Vera - Yanıt
That’s a good question. As for the previous models it is very hard to find those rubber gaskets. Using a “liquid rubber gasket” might be one solution to that. (Use carefully to not spill too much on and into the watch)
Tobias Isakeit -
I tried to remove all of the screws from the back cover, but 3 of the 4 screws remained and seemed to be fused to the main base of the watch. One of the screws was stripped. Now only 1 screw is engaged with the back cover. (I might need to replace the back cover. My watch is glitching which is draining the battery. I would like to fix the problems myself. Where can I get specific advice?
Antoinette - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 134
Her zaman: 2,561
