Ana içeriğe geç
Opening the Hood
  1. Opening the Hood, Opening the Hood: adım 1, 2 resimden 1. Opening the Hood, Opening the Hood: adım 1, 2 resimden 2.
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
    FixBot'a Sor
    Yorum Ekle
  2. Opening the Hood: adım 2, 2 resimden 1. Opening the Hood: adım 2, 2 resimden 2.
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
    FixBot'a Sor
    Yorum Ekle
  3. Opening the Hood: adım 3, 2 resimden 1. Opening the Hood: adım 3, 2 resimden 2.
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Shaun MacDonald
2.654 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G27
4 Üyeler
24 adet Kılavuz yazıldı
1Rehber Yorum
Whats next after opening the hood? How to check for the hood latch? Where is it located? Need to check for the cause why the alarm keeps going
off at odd hours. The car has lojack and a car alarm. Changed the FOB key that didnt worked. Manually opened the door with key. Not happening problem still exist. Need help with what other options.
boomanison - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 51
Son 7 gün: 286
Son 30 gün: 1,397
Her zaman: 84,054
