Ana içeriğe geç
Optical Bay Enclosure Dual Hard Drive Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
  1. Optical Bay Enclosure Dual Hard Drive Replacement, Dual Hard Drive: adım 1, 2 resimden 1. Optical Bay Enclosure Dual Hard Drive Replacement, Dual Hard Drive: adım 1, 2 resimden 2.
    • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  2. Optical Bay Enclosure Dual Hard Drive Replacement: adım 2, 3 resimden 1. Optical Bay Enclosure Dual Hard Drive Replacement: adım 2, 3 resimden 2. Optical Bay Enclosure Dual Hard Drive Replacement: adım 2, 3 resimden 3.
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  3. Optical Bay Enclosure Dual Hard Drive Replacement: adım 3, 2 resimden 1. Optical Bay Enclosure Dual Hard Drive Replacement: adım 3, 2 resimden 2.
    • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brittany McCrigler
89.745 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.450 adet Kılavuz yazıldı
Bir Yorum
Great guide, however I think you overestimated the difficulty of it. The biggest challenge is not stripping any screws and being sure to have all sizes that you may possibly need including some that might not be standard because stripping screws is very possible. Otherwise, nice job
Rob Anthony Dire - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 12
Her zaman: 275
